Localization/translation of Web CLient
Jaisal
I am trying to translate 3CX Web Client following the document https://www.3cx.com/blog/docs/localize-3cx-phonesystem/ and not seems to be working. After adding the new language, it is not appearing in Language list.
How do i successfully translate 3CX v18 on Debian 10 ?
Hi @Jaisal,
The document which you linked isn't valid anymore, that was valid till V14 as it mentions. While you can't change the flag or the name, you could perhaps overwrite an existing language by navigating to /var/lib/3cxpbx/Data/Http/wwwroot/webclient/i18n/.
Note that I don't recommend this as if an update occurs, your file will be overwritten.
Thanks you . That worked.
Is there a workaround to change the language name and flag ? or a recommended method for translation ?
Hi @Jaisal,
Unfortunately not at this time.
megalmazan
