Login/Logout bridge extensions to Queue's
J_Hermsen
I have created some dummy extensions with mobile and ring simultaneously.
Now I can login / logout to assigned queue's using the webclient, but is there a way to use dialing code to login in?
I tried (bridge prefix)*62 and the promp sounds good, but it isn't signed in as I guess it comes in with the CID of the origin bridge extension (remote prefix+ext).
Hello @J_Hermsen
If i understand the requirement correctly then this is not possible. You will need to use the web client to change the status of the extension.
rmf
