but the weird thing is that i changed nothing. i used the admin username as standard and now i am locked out?...You can't. However, if you are using the right username, a link for "Forgot Password?" should appear below the login. This will allow a password reset via the admin email in the system.
thanks for the tip "forgot password" option. I have again access to the admin panel.You can't. However, if you are using the right username, a link for "Forgot Password?" should appear below the login. This will allow a password reset via the admin email in the system.
Founded in 2005, when VoIP was an emerging technology, 3CX has gone on to establish itself as a global leader in business communications.
