Solved M365 Sharepoint Storage Logs
YuriStrife
Is there somewhere where the logs can be viewed for M365 Storage.
One of our servers has suddenly stopped moving items to the Sharepoint as of around a month ago and the recordings filling the disk.
Strangley only recording where not auto archiving as the Weekly backups still went to the sharepoint without issue.
I was also stil lable to access and download recordings and could see the file structure as when a new folder was created it could be found when selecting a folder/Path.
I have removed the app registration and reconfigured the integration but items still do not seem to be moving to the archive automatically or if I perform a manual archive of a file.
We are currently running Version 20.0 Update 8 (Build 1121 Release) hosted in Azure.
Solution
@YuriStrife as an addon to the previous response form my colleague, if you go to the Admin Console >> Integrations >> Transcriptions, do you see any error there ?
Did you use in the past 3CX Transcription Service ( Cloud ) ?
You should be able to see something in verbose logs, but as a first step, did you do a services restart, to see if it clears out and the backups go?
Reactions: Brendan D
Solution
Thanks Nikos.
It was the transcription preventing the files from being archived.
KylieWilderman
