Solved Machine is not reachable. Please check the internet connection and firewall settings of this network.
rbezes
New User
My hosted instance is not reachable, and I have not received any advice on adverse usage.
I m a free 3CX Standard,
I not "at least 15 calls OR chat messages per week"
It's possible to reactivate
Thank
Hi, your machine has been re-activated but please note that by the time the machine is in Trial License key, then if the PBX is not used, on the next checkup from our systems if the criteria is not met, then the machine will be powered off again.
I would highly recommend to use your PBX actively and then there will be no issue at all.
Kayla Norris
