- Joined
- Jun 20, 2018
- Messages
- 4,476
- Reaction score
- 2,190
I updated a few servers to 18u4 tonight (yes they're behind). One (only one) prompted afterwards to update the MacOS Desktop App from 18.8.508 to 18.9.933. I told it to but after a bit it showed error:
Could not find a part of the path '/var/lib/3cxpbx/Instance1/Data/Http/electron/osx_temp/3CX Desktop App-darwin-x64-18.9.933.zip'.
On the server it seems to be here instead, without spaces in the filename:
# ls -l /var/lib/3cxpbx/Instance1/Data/Http/electron/osx
total 191724
-rw-r--r-- 1 phonesystem phonesystem 196320471 Sep 22 17:49 3CXDesktopApp-18.9.933.dmg
-rw-r--r-- 1 phonesystem phonesystem 180 Sep 22 17:49 version.xml
If I go to a different page and back again, the update page does not show it as a pending update anymore. Is this a bug? Glitch to ignore?
Thanks,
total 191724
Thanks,
