- Joined
- May 6, 2013
- Messages
- 35
- Reaction score
- 0
Hello community.
I will try to explain this as smooth as possible so bear with me
I have two PBX, let's call them A and B. I am located in B and I'm trying to do the following from A:
I have two NIC's on PBX B with two different Internet connections (2 ISP), it doesn't matter which is the active default gateway, calls will go in and out from/to B. The issue resides that I have all my trunks and routes, etc in PBX A (inbound/outbound connections are made using A even though I'm located in B).
I have the [ivr-3] context in extensions_custom.conf in PBX A in order to make a direct connection to extensions in PBX B when a call is in the IVR in PBX A (all routes and queues are properly set up), I have the following [ivr-3] context in PBX A, changed the names of the Trunks so it will not show the real trunk names for this purpose:
[ivr-3]
exten => _2XX,1,dial(IAX2/Backup-Trunk/${EXTEN})
exten => _1XX,n,dial(IAX2/Backup-Trunk/${EXTEN})
exten => _2XX,1,dial(IAX2/Primary-Trunk/${EXTEN})
exten => _1XX,n,dial(IAX2/Primary-Trunk/${EXTEN})
When I'm using one of the default gateways I have to manually change the order of the trunks in the route and also have to change the trunk order in the context, so finally the question is:
Is there a way to make it jump to the next instruction or a next context if a connection is not made to the extension? As of right now, the call will not go through as it will give me a busy tone when trying the first lines (if default gateway is the opposite), is there a way to tell Asterisk that I'm using another Default gateway so it must use the following lines or a different context?
Hope this explanation is clear to you, if not, let me know if anything. I will really appreciate your words of wisdom on this one since I have to be making manual changes whenever one ISP fails.
Thanks in advance.
[ivr-3]
Thanks in advance.
