MAKE CONNECTIONS BY A SPECIFIC TRUNK
salinbraga
I have extension 1201 and I want to use it to connect to trunk x and extension 1202 to connect through trunk y I did the exit procedure and it still goes out in just 1 calling from any extension, how can I do that?
Use the outbound rules filtering on Extensions or Groups.
Reactions: YiannisH_3CX
...and place the extension specific rule you create, above the "general" rule that all other extension use. Rules are read from top down.
Senergia
