Management console will not display properly
FuTech-Nel
I just upgraded a client to the 16.0.6.641. and ever since the update, their management console will not display properly on Firefox ESR 52.9.0 (they are using this version due to the limitation of the server OS).
How do I fix this see attached examples.
im wondering what server limitation you're referring to?
3CX MGMT console supports Edge, Chome and Firefox tested with the latest version.
Have you tried using Firefox ESR 68.12.0?
The 3CX software is installed in a linux machine and I access the console through their file server.
They are running Windows server 2008 Standard.
Same problem here with a Debian 3CX 16.0.641 and Firefox 68.12.0esr on Windows 10 Pro. No pohones listed.
Chrome 85.0.4183.83 works.
[email protected].
