Manual setup of Yealink T54W via STUN?
orange2
I do not want to auto provision this particular phone. I just moved the customer's server to AWS, thus the phone needs to be set up manually to connect via STUN. Anyone know how to do this please?
Can you log into the Web config page for the phone?
I have configured a Snom D385 this way. It just takes a bit of time ensuring that the correct info is added as it isn't laid out the same as 3CX.
On page 3 of the attached manual it shows you how to log in and edit the settings.
You will have to get the server settings from your 3CX management console for the extension you want to set up.
Brill thanks. I use both Snom and Yealink so will hopefully be ok transcribing the one the the other!
Sadly the manual doesn't refer to testing STUN. Back to the drawing board!
@orange2
If you don't want to provision the whole phone then you don't have to use STUN.
Just add the 3CX extension credentials into the desired SIP account and you are ready to go.
3K8iMGWviZ
