Solved Meeting Not Found!
AlanLatteri
Forum User
every user, every time with any Video meeting we try to create.
Hi Alan,
Is your HTTPS port open? As a test example, can you access your webclient at the following address format?
Example: https://myFQDN.3cx.com:5001/webclient
Hi Alan,
Check your event log on the dashboard to see if there is a message regarding webmeeting
The problem you face means that the PBX cannot communicate with the webmeeting servers to inform them of the meeting creation, and hence you are trying to reach a meeting that does not exist because it was likely never created on our servers in the first place.
Can you please confirm the following points?
  1. Make sure your certificate is valid and not self signed.
  2. Port 5001 or 443 is open for bidirectional communication with webmeeting.3cx.net
  3. Make sure your extensions at least have a Name or a Last Name
  4. Your extensions MUST have an e-mail for WebMeeting to work.
  5. Make sure your PBX's FQDN is resolving properly. If not, after a long grace period it's WebMeeting meeting data will be deleted as you'd be considered inactive
  6. Restart your 3CX System Service. This resyncs important data between your PBX and the WebMeeting server.
reboot of the server fixed it.
thanks.
Glad to hear!
Graham Robertson
