Solved Menu screen sharing is empty
VSC
Forum User
When I start a webmeeting using Chrome (Version 95.0.4638.54) I can not share my screen as the menu item appears empty. Whereas if I use Firefox all works as expected.
What can I do to get this working?
Add-Info: Another teammember who is using same version of Chrome can see the screensharing menu.
That probably makes me think that this is something to do with the browser itself.
Have you tried clearing all cache?
Possibly also uninstall Chrome, cleanup, then re-install?
Reactions: Evolute IT and VSC
Thanks for your prompt reply. A complete deinstall including all browser data was helpful.
Reactions: NickD_3CX
Glad to hear that helped! :)
Graham Robertson
