"merging calls" problem
wlady
I've a very strange problem with a elastix 2.0.0 PBX connected with a VOIP trunk (no additional cards, only connected to internet with normal ethernet conn).
When I receive a second contemporary call my first call often fall or I can't hear the interlocutor until second call is closed. The harshest thing is that the second caller can listen to the first call for a while !
What's going on?
Thanks!
What does your voip provider tells you about this issue?
They say it's only a my problem :(
Re:
It actually sounds like a Nat issue to me. The streams are getting crossed. But I am still pretty new to this. Is the on a Public IP? Are you running a sip helper on you firewall?
Robert
CLTedu
