Solved mgmt console blinking uncontrollably after update to 15.5
asinshesq
I just auto updated to v 15.5 and now, when I browse to the management console (locally…on my setup, it’s at http://192.168.1.201:5000), the browser rapidly blinks in an uncontrollable way and is thus unusable. How do I fix that? Or am I not supposed to be using the browser interface for the new version? Or do I need to reinstall? In case it’s relevant, when I upgraded I got two concurrent emails: the first said “Your 3CX Phone System has been successfully updated!” and the second said “A new update is available for 3CX Phone System. Login to the 3CX Management console….”
I should have mentioned that after the update, the phones work fine so 3cx is still working perfectly. I just can't use the console.
Solved. I was able to log in using a different browser. I then continued auto updating and then I tried my original browser and it made re re-login and everything then worked.
Glad to see the issue has been resolved and thank you for updating the thread with your solution.
Bluebox Global
