Microphone device connect to 3CX
George Stavrianos
Hello to all,
I would like to add a microphone device (IP Microphone) as user to 3CX users to make call from this and to the device menu must be fill some fields as below
Server: IP pf my 3cx server or the name
Port: 5060
Username: ?
Account:?
Password:?
Expire time:600
I created a user, but i cannot provisioning this device with the created user.
Do you know what i fill to the fields with questionmark?
If there is a way to solve my problem , please inform me.
Thanks a lot
Username: Auth ID
Account: Extension number
Password: auth password
Username: Auth ID
Hello thanks for your quick reply but on username filed does not accept more than 4 characters eg.1000.
I think that to fill like below
Username: extension number
Account : auth id
password: auth password?
is it correct?
Account : auth id
is it correct?
Possibly. Try it and you'll know lol
Weird if it stops at 4 since some system use 5 digits lol
ok but the authentication id is more then 5 digits
I think that is not the correct filed filling
Also i can call the user to the microphone device but can call from the user
You can set whatever auth id you want using the management console.
Hello thanks for your answer but the problem remains.
I filled the fields as below
Server: IP of my 3cx server or the name of server
Port: 5060
Username: the extension of created user (501)
Account: Authentication id (from phone provisioning tab of user)
Password: Password id (from phone provisioning tab of user)
Expire time: 600
The problem is that, when I call the 501 from another extension , the IP microphone device is ringing and I can answer the call, but when I try to call from the IP microphone device (501) to another extension e.g. 520 the call is coming to its device and not routing to the device which is called.
So, I cannot do outcoming call but the incoming calls working perfect.
Does anyone knows how to resolve this problem?
Also the attachment file includes the activity log. I think that the problem is about authentication ID and password ID from phone provisioning tab
mazet
