Migrating to 15.5 SP2 from 15.5.3849.1 / new VM
Dave Braford-Grimes
Can 2 instances of 3CX co-exist with the same license keys?
IE - we'd like to restore a backup from our running 3CX PBX to a clean install on a new VM.
Then, we change IPs, etc.
Naturally 3CX will expect that you only run one instance. The Enterprise edition is required if you want to keep two instances (fail-over option). You can activate the same key more than once (to briefly prepare for an upgrade), but be aware that every time to register your key on a different computer this information is captured and carefully monitored by 3CX. I would suggest you make a call to 3CX Technical Support to see if you have any activations remaining on your key. You don't want to run out of activations while performing the upgrade during hours where no technical support is available. Don't forget that changing the 3CX IP is a bad idea. So, backup the original server and turn it off. Then start the new server with the correct IP address, and reinstall the server on the new server. Further, things can get messy with the Web Conferencing service too if you have two computers with different FQDNs registered with the same key. I should also point out that I've had some really screwy things happen when you have multiple 3CX servers running in the same local subnet. You either need to isolate the old and new servers, or you should turn the old one off before working on the new server. My preference when upgrading 3CX is always to keep the original server intact as a fall-back option in case the upgrade doesn't go well. Sorry, that's a long answer when I could have simply said "yes" you can do it.
No problem, thanks for sharing your experience with 3CX.
We have to change the IP, that can't be avoided.
I was planning on trying the migration on the weekend, maybe that's not such a good idea.
Hello @Dave Braford-Grimes
As mentioned it is not a good idea running 2 instances with the same licence key so i would recommend creating a backup of your current machine powering the machine down and then restoring the backup to the new machine.
I would also recommend restoring the backup on the latest version of the 3CX as the latest version supports local IP changing.
That is what I was planning to do, but, need to change he IP.
1) install latest on fresh VM - done
2) add license key and apply all updates.
3) restore latest backup from previous 3CX.
4) change IP on restored PBX to new IP ???????
5) re-provision phones, etc.
Are you saying previous versions didn't allow an IP change?
Actually, it's news to me that one of the changes in SP5 is the ability to change your local IP address. Prior to SP5 to change the local IP address you had to reinstall.
The procedure i would follow is the following:
  1. Perform a backup without including licence and FQDN information
  2. Power down the original machine
  3. Install latest 3CX version on fresh VM
  4. restore latest backup from previous 3CX.
  5. Re-provision phones.
Are you planning to use the same local IP as before or are you planning on using a new local IP?
This was actually introduced before SP5
