Mitel 6800 with 3CX v16
Franky_Nubecom
Intermediate Cert.
Hi All
I'm trying to connect Mitel 6800 series phones, I know it is not supported phone, but want to see if someone get success to get one register and what is config he used or get some screen capture, please
I read other thread but they are old
so trying a new one
Thx
For on-prem or vpn pick the closest matching aastra 67xx series phone from the list and it will probably work. I haven’t tested but they are the older series of the 68xx so it’s likely they will be compatible.
To use for remote stun you will have to manually configure. Likely won’t work with the sbc.
good luck. Best to replace with Yealink phones which are a dream to setup.
Yes I know, I try to configure for remote user, so with STUN I didn't get a lot of success
not sure why the phone dowsn't want to register with basic information that normally we use
Thx
martinschilder
