Mobile client cannot show call logs
TimoM
3CX V20 is no longer showing call logs in the recents tab. Neither is the web client in the calls tab. The calls however are present in the reports>call log.
Anyone experienced this?
Timo M.
Hi @TimoM
Can you check the event log for any errors mentioning a loop? If so, check and ensure you remove all loops. A loop can be created by a queue sending the call to another queue and then back, or extensions forwarding calls back to their own extension, etc.
Also, we can see that there is a partner assigned to your key, and we suggest checking with them to open a ticket to technical support on your behalf.
SDNM
