Multiline TAPI Mass installation
IT engineer
Forum User
As title says: How can we make a mass installation of the multiline TAPI?
e.g. from Lansweeper?
It always fails because I think we need to enter some telephone numbers, names in order for the installation to continue.
May I ask for which Application you require mass Tapi Integration?
For the Adito CRM
I would strongly suggest to do it another way given this information
14021
and our felibale integration option
https://www.3cx.com/docs/crm-integration/
Check with the vendor if they can join this for you together.
Thank you for your reply. Right now we only configure it in a way that we absolutely have to do a mass depolyment of the multiline TAPI.
In the future we are going to change the entire method of connecting to the CRM.
Did anyone else try a mass deployment of the multiline TAPI?
3K8iMGWviZ
