Multiple 3CX accounts - only one rings after update to v15.5.344.492
ThePhoton
Device Info
Phone Model: [Samsung Galaxy S8]
Firmware Version: [8.0]
Issue Info
Handset: [3CX Android App]
Contacts: [N/A]
Connection: [Wifi or 3G]
Server: [Either]
After the latest update to v15.5.344.492, and having multiple accounts configured in the 3CX Android app, only the 'active' one (in the switcher) seems to receive calls.
Previously, either account would ring when receiving a call, and obviously you could make calls from the active account in the switcher.
Is this a bug or expected behaviour?
Accounts are configured from two separate 3CX servers - work and home. Both servers running the latest update 5.
Matt
Hello @ThePhoton
Please note that as far as i remember this never used to work. The client would only accept Push requests from the last active account.
Thanks YiannisH - I probably imagined it working then!
Is this likely to remain the case after the server has been updated to update 6, or since 6 will allow multiple devices to receive push, will this 'fix' the issue that I'm experiencing too?
I do not think that this behaviour will change as the update will enable the PBX to send multiple Push requests to devices that are running the same account.
Mahlon
