Mysql Connection from CFD is not working but from CRM Integration is working
Goga
Titanium Partner
I try to connect to Amazon Mysql Database using 3cx CFD I cannot connect and it show error as below.
From script: inboundmap - CallID 0000018ED6BADA6A_12842 - Callflow - Error executing last component: MySqlConnector.MySqlException (0x80004005): Connect Timeout expired.
---> MySqlConnector.MySqlException (0x80004005): Connect Timeout expired.
at MySqlConnector.Core.ServerSession.OpenTcpSocketAsync(ConnectionSettings cs, ILoadBalancer loadBalancer, Activity activity, IOBehavior ioBehavior, CancellationToken cancellationToken) in /_/src/MySqlConnector/Core/ServerSession.cs:line 1131
at MySqlConnector.Core.ServerSession.ConnectAsync(ConnectionSettings cs, MySqlConnection connection, Int32 startTickCount, ILoadBalancer loadBalancer, Activity activity, IOBehavior ioBehavior, CancellationToken cancellationToken) in /_/src/MySqlConnector/Core/ServerSession.cs:line 438
at MySqlConnector.Core.ConnectionPool.ConnectSessionAsync(MySqlConnection connection, String logMessage, Int32 startTickCount, Activity activity, IOBehavior ioBehavior, CancellationToken cancellationToken) in /_/src/MySqlConnector/Core/ConnectionPool.cs:line 403
at MySqlConnector.Core.ConnectionPool.ConnectSessionAsync(MySqlConnection connection, String logMessage, Int32 startTickCount, Activity activity, IOBehavior ioBehavior, CancellationToken cancellationToken) in /_/src/MySqlConnector/Core/ConnectionPool.cs:line 408
at MySqlConnector.Core.ConnectionPool.GetSessionAsync(MySqlConnection connection, Int32 startTickCount, Activity activity, IOBehavior ioBehavior, CancellationToken cancellationToken) in /_/src/MySqlConnector/Core/ConnectionPool.cs:line 98
at MySqlConnector.Core.ConnectionPool.GetSessionAsync(MySqlConnection connection, Int32 startTickCount, Activity activity, IOBehavior ioBehavior, CancellationToken cancellationToken) in /_/src/MySqlConnector/Core/ConnectionPool.cs:line 128
at MySqlConnector.MySqlConnection.CreateSessionAsync(ConnectionPool pool, Int32 startTickCount, Activity activity, Nullable`1 ioBehavior, CancellationToken cancellationToken) in /_/src/MySqlConnector/MySqlConnection.cs:line 929
at MySqlConnector.MySqlConnection.CreateSessionAsync(ConnectionPool pool, Int32 startTickCount, Activity activity, Nullable`1 ioBehavior, CancellationToken cancellationToken) in /_/src/MySqlConnector/MySqlConnection.cs:line 959
at MySqlConnector.MySqlConnection.OpenAsync(Nullable`1 ioBehavior, CancellationToken cancellationToken) in /_/src/MySqlConnector/MySqlConnection.cs:line 423
at CallFlow.CFD.DatabaseAccessComponent.PrepareCommandAsync(DbConnection conn)
at CallFlow.CFD.DatabaseAccessComponent.ExecuteReaderAsync(DbConnection conn)
at CallFlow.CFD.DatabaseAccessComponent.ExecuteStatement(DbConnection conn)
at CallFlow.CFD.DatabaseAccessComponent.ExecuteStart()
at CallFlow.CFD.DatabaseAccessComponent.Start(TimerManager timerManager, Dictionary`2 variableMap, TempWavFileManager tempWavFileManager, PromptQueue promptQueue)
at _9001_6.Main.ProcessStart()
But when I try using CRM integration Mysql connection it is working.
I tried using PHP it is working.
Tried on both 3cx V18 latest and V20
Interestingly I am able to connect to other Mysql database hosted on Digital Ocean.
Only Amazon Mysql database I am not able to connect .
I tried using IP also instead of DNS still not working.
Connection timeout it says. There must be something blocking the connection, or you misconfigured the database component. Specially ports and such.
But I used same port in CRM Integration and it is working ..
This is related with the connection, maybe there is no response to the PBX as the connection will timeout.
A connection timeout is a firewall issue in 99% of the cases. You should check your CFD app configuration, if this is working fine for the MySQL integration in 3CX, then maybe you're pointing to a different server.....
KylieWilderman
