Solved Need Some help
VortexShield
Forum User
Hi, we are new partners for 3CX, we would like to use the standard free version of 3CX (hosted by 3CX) for ourselves but i do not see any options of Keys on my partner portal. How do i go about.
@VortexShield you may use the hosted solution of 3cx with a Trial keys, Pro, Enterprise or your NFR keys.
Create a Try key and then next to the key you will see option " Deploy to Hosted " .
Please check this and then give us your feedback.
Thanks, where can i find the trial keys, i do not see any on my partner portal.
@VortexShield on the left side there is section "Keys" . If you click it you will see your NFRs and under that on the right side with see " Create Try License "
@nikosT_3cx - I do not see "Keys" section on my portal at all. i only see subscriptions, instances, get support, Get certified , my account...
@VortexShield it seems you have logged in with end user account and not partner account.
I would recommend to send an email to [email protected] and our Customer Service Team will guide you accordingly with your account.
ICTSupport@bedfordgirlssc
