Need to change the 3cx FQDN
Selvan-Prosys
How to release the current FQDN in 3cx portal and assign the new FQDN? please share the steps of 3cx documents for the same.
Hello @Selvan-Prosys
To change FQDN you will have to first stop the current installation, then disconnect the FQDN from the License.
You can do this by logging to the portal with the Owner of the License key credentials.
Find the License Key, click on it and the Disconnect option will be available.
Hi @Dimitris_3CX ,
Thanks for the details. We couldn't see disconnect option in FQDN?please advise.
Can you please clarify if you have logged with the Owner of the License Key credentials?
We are Bronze partner and logged in to the 3cx portal with our partner account. Do we have to login 3cx portal using customer registered email ID or 3cx Distributor only will have the license ownership & FQDN disconnect option? please advise. Thanks.
You will have to log in to the 3CX Portal with the registration email address.
As I can understand from your reply, this should be the customer's registered email.
Hello Dimitri.
What do you mean by "stop current installation"? I have an installation which we need to change the FQDN and we want to avoid reinstalling. I already know how to release the FQDN.
Hello @10m,
In order to change FQDN you will need to stop the current installation, disconnect the FQDN and re-install the system with the new FQDN.
Hello Dimitri.
Reinstall is always the way to go.
I think I realised that when I went through other posts. I have taken the option to reinstall with a fresh license.
Reactions: bitn2
tom.walker@blackcountryra
