Need to configure 3cx
Readyspace
I have purchased 8 numbers. Yealink T40G phones and would like to configure 3CX to myRepublic credential.
SIP Server: sip.myrepublic.com.sg
SIP Port:
Protocol: UDP
SIP Port: 5060)
Beside also need to configure the Android phone to match the extension of the Yealink phone so that both mobile phone and YEalink phone will ring at same time.
Please help on this.
There is a lot of information on the 3CX site dealing with the initial configuration if you do some searches. Here is but one link...https://www.3cx.com/docs/
If your provider is NOT a 3CX approved provider, then it becomes a bit tricky if they use a "non-standard configuration". There may be forum members that also use that provider and may be able to offer assistance.
I would suggest maybe going through one of the training things on the website. It sounds like you dont have experience in setting them up if you are asking how to do it :)
Hello @Readyspace
Just to add that your requirements are doable and easy to setup. You will need to become familiar with the software to be able to easily setup the requested requirements. The 3CX academy is a very good place to start.
megalmazan
