Solved New Install - Elastix Conversion
OS-Milton
used an elastix / Issabel backup and the conversion tool to import existing extensions - seemed to work...
-- Sip Trunk Edit -- Error 500
Object reference not set to an instance of an object.
Not editing an extension so Template shouldn't be the issue... / is it?
Mostly appears ok but trunk is not working correctly.
Have a SIP trunk to a G200 Digium with PRI connected to it.
Currently have a working Older Elastix - Newer issabel test as well. - those all work fine through the sip trunk.
import config did create a trunk but I need to edit the config to use a new SIP Endpoint config that I have .. just a different username basically so I can manage the call rules a little better.
but get the error on any edit of that trunk.
would like to test with some options of 3CX having Calls route to Elastix so I can have both setup and maybe migrate however not sure with the 500 Error with almost no debug..
Never mind
Solution ended up easier..
just delete imported config for trunk and rebuild with new name-
then worked fine and registered as expected.
