Solved New PBX, new T53W phones, not provisioning
voxclear
Starting with the extension configured as SBC, upgraded to 96.86.0.74 firmware. Provisioning skipped on restart. Tried a second T53W, same thing after upgrade. Firewall rule set up for cloud PBX instance and is accepting traffic to and from that. So i suspect FW is blocking the Yealink RPS. Anyone else encounter this? I don't know the IP address for it yet.
Check if you have dhcp 66 on your dhcp server and remove it.
Reactions: voxclear
Thanks for the suggestion. It was that I was not using the current method of adding phones from the webclient portal (instead of the admin portal.
Finatra.us
