New v20 install on premise VPS
Dear bitn2
I have a Hetzner VPS CX22 with a static public IP (3cx requirements are fullfilled)
Hetzner provides official ISO to mount and install 3CX, I did this, all goes fine without any error.
At the end I get my URL with my public IP to make the installation.
On my 3CX account panel I have created a new instance ON PREMISE and at the end I get a SetupConfig file or a link to paste in the setup process.
I copy the URL and paste into my install, after is press NEXT I get the error:
Invalid option selected
SAME happens uploading the file.
Just a guess, do you have any special characters or ‘ or similar characters in your license info?
No, the only "special" character could the phone number in format +(countrycode)number...
Dear bitn2
Same here, also Hetzner.
I've also tried to reinstall the VM 3 times, the issue persists.
I asked support to upload a different ISO file, lets see how that works...
We have a lot of customers with 3cx hosted by hetzner and not with any one we have a problem to install with the config. Just did it a fiew days ago. There must be something with your config file.
EDIT: if you dont mind, you can send me your config file and i can check it for you.
the problem is specific to Hetzner as the same XML file works fine when I use it in hyperv.
Maybe the ISO is bad or something else. The support from hetzner is pretty good, jjust give them a call.
He ran the install via cmd too irrelevant to the ISO and the same thing occurred. Are you saying you can spin up CX22 and use the URL?
We allways use the file not the url, but this wasnt any problem
I've tried uploading the file too. Ill have a play once i've verified myself on Hetzner, cant be bothered getting my ID from the car at the mo
Cx22 and cx21 (the old one)
Then I don’t know what it can really be…
I have tried installing with Hetzner 3cx iso and also with plain Debian12 and then manual install and I get same error on both scenarios…
SOLVED !
Dear all I managed to solve the issue: for those who might have the same problem, please completely delete your VPS instance and create a new one, it might be the VPS was corrupted somehow.
Then I installed a clean Debian 12 and run following command to install:
wget -O /tmp/post-install http://downloads-global.3cx.com/downloads/debian12iso/post-install_12.1.0_46a7ea2.txt; chmod +x /tmp/post-install; bash /tmp/post-install && bash /usr/local/bin/post-install
Now with the completely new VPS everything works like a rocket!
Thanks to all you users for the support, especially to Alphabetic !
Thanks also to all 3CX team!
But keep in mind this is unsupported. You need to use the ISO to get a supported installation.
Reactions: N_G and Evolute IT
In the past i managed to install several instances without any problem. Today i tried to install a new instance for customer demo and couldn't manage to pass the config file upload step, i got the error "Invalid option selected".
I tried with 2 different SetupConfig.xml downloaded from https://install.3cx.com/?license=XXX....
3CX was installed on a VM (tried proxmox, vmware...) using the officials ISO and guide.
Backup Restore didn't work either because of wrong version (backup version is too recent compared to installer version).
I agree that 3CX installation is now really easy, but the process seems to be broken somewhere, or misses some error details or alert so we can investigate further more.
I guess i have no other choice but installing 3CX the old way, like @albadream did.
I would check what wrong option do you choose. The blank xm file shouldnt make any problems. Did you customized something? Did configured the firewall before?
Thanks for you answer :)
No i haven't done any modification on the blank xml. Used it straight forward. I tried both using a custom fqdn and a .my3cx.fr domain, same issue (thought it could be a certificate issue, but no).
I have checked my firewall and DNS setup, i think i have done everything that was needed. Also, i already have another 3CX instance running for my personal use in the same local network that i could install without issues a few months ago.
This is the first time i'm having this issue.
Diogo Maia
