Solved nginx returns 502 Bad Gateway
A.Takacs
Hello
Title says it all - any web access returns that error (self hosted debian). Aynthing to do except a hard reboot ?
There could be any number of issues, so a re-boot is not guaranteed to fix it, but worth a try.
You'll need to provide additional information.
Thanks - no ssh access either :(
Will have to manualy reboot it
Hi @A.Takacs,
Can you PM me the license key to take a look, if this has not been resolved?
Turned out to be a defective disk :( Haven't had such a hardware issue for ages...
Yes, not usually the first thing that comes to mind to troubleshoot. Great that you got it up and running @A.Takacs!
devo.it
