No audio from 3CX
Psevdokounian
New User
Hello. A have a problem with audio. When i'm calling from external number, i hear audio form external but when i'm speaking no audio.
Please, help me)
3CX Version: 16.0.611
Server OS: Windows Server 2016
Is the 3CX Server Hosted and where: Hosted on my ESXI Server
IP Phone Make/Model/Firmware: SNR VP-52/VP-56/VP-80
Provisioning Method: Local / VPN / STUN / SBC: Local
Trunk Provider or Gateway Make/Model: UzTelecom
Has the Firewall Checker passed: No (Because in providers closed network)
Are custom Phone Templates being used: NO
No firewall used, connecting through providers switch. I have 2 ethernet adapters now. Early i used 3CX with 1 adapter and telephony worked over the Internet. Now i added 2nd adapter, added new route and deleted from 1 adapter DNS and gateway. Now i have internet on 1st adapter and normally working 2nd adapter with telephony. But... I hear soud from external call, but when i speaking no sound.
Reactions: JohnS_3CX
My route is configured like in your link. Same problem.
I'm guessing, that , for whatever reason (a 3CX setting), 3CX is sending the audio packets, externally, on the wrong NIC. Since it was working correctly, in the past, when you were using a single NIC, what prompted you to make use of a second?
Reactions: Psevdokounian
Yeah... Now we found solution. Thanx in advice.
Problem solved with right routing table, this is my mistake, i have not propetly configured a routing(My low skils in networks). Now i configured a metrics and routes to interfaces. it worked propetly)))
Ok, now my 2nd office can't connect to 3CX. Ping are working, but no connection with 3CX.
Try running the 3CX Firewall Checker, and see if the ports all pass. I have to assume that this is something to do with the changes you've made, causing this to now happen.
SCarpenter@fifthavenue-la
