No Audio, Incoming or Outgoing
sethlocks
I had to replace my comcast router with the same model in bridge mode and a new router. After rebuilding config, none of my extensions will transmit audio on external calls. Internal calls have audio between extensions. I have passed firewall checker. Here is the log:
04/23/2018 10:01:41 AM - [CM503021]: Call(C:20): ACK is not received from sip:[email protected]
04/23/2018 10:01:14 AM - [CM102001]: Authentication failed for AuthFail Recv Req REGISTER from 192.168.77.97:5060 tid=-5fef9968 [email protected]: REGISTER sip:192.168.77.106:5060 SIP/2.0 Via: SIP/2.0/UDP 192.168.77.97:5060;branch=z9hG4bK-5fef9968;rport=5060 Max-Forwards: 70 Contact: <sip:[email protected]:5060>;expires=60;+sip.instance="<urn:uuid:00000000-0000-0000-0000-9cadef63e2ca>" To: <sip:[email protected]> From: <sip:[email protected]>;tag=SP1afbf96266fef0e21 Call-ID: [email protected] CSeq: 41695 REGISTER Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, PRACK, REFER, UPDATE Proxy-Authorization: Digest algorithm=MD5,nonce="414d53595addf53a33:ea190f3cc2a4eb3e20865b47f29a748b",realm="3CXPhoneSystem",response="c8db4a60fa4ca6cf4fd1678ecd61d045",uri="sip:192.168.77.106:5060",username="iju0dv7" Supported: replaces User-Agent: OBIHAI/OBi200-3.2.1.5735 Content-Length: 0 ; Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
04/23/2018 10:00:59 AM - [CM503021]: Call(C:19): ACK is not received from sip:[email protected]
So...you have a Comcast Router, with a LAN port set to Bridge mode , then another router (a new one also?) plugged into that?
I that is the case, why was the second router replaced? Is the second router "getting" a public IP through the Bridged port from the first?
First router was a comcast all in one. It began to have issues with Wifi, so it was replaced and the comcast router put into bridge mode.
And a second router is plugged into the first?
And it has picked up a public IP?
aatroxadrian
