No e-mail on reports
daktur
Hi Everyone!
Is there a way to do not send the report via e-mail? It doesn't make much sense when the admin is running reports to be forced to send their link via e-mail. Since he is already in the admin console to access the file generate.
I understand when you schedule a report is amazing to receive it directly to the email but the e-mail seems to be a required field evend when running a one time report.
Is this correct? Does anyone know if there is something related on the Ideas forum?
Thanks.
Hello @daktur
The email field is mandatory when running a report at the moment and i cannot remember if there is something in the ideas section regarding this so it could be worth creating.
For now you can always use a dummy email address if you don't want the reports delivered to your email.
Hello @daktur
Hi @YiannisH_3CX, thank you for your suggestion however even a dummy email needs to exist otherwise the error messages generated get to the reply to inbox. Very inconvenient.
I will take a look o the ideas forum to see if something similar was posted.
Thanks again
Herm77
