No External Calls on TalkTalk
StartPlus
As most people we have a number of users working from home at the moment.
We use Yealink T46 phones, most users are okay but one of the phones is on a home broadband TalkTalk connection, internal calls work fine but cannot receive any external calls and call transfer doesn't work.
Can’t find any way to contact TalkTalk.
Anyone come across this before?
Not a great deal of information to go on.
I'm assuming that the home user with the issue has their phone set to use STUN (or it should be). Some routers,especially those supplied by providers, don't play well with SIP, don't allow you to make any routing/port forwarding changes, and may be equipped for local SIP phones, therefore making use of ports that the 3CX extension is attempting to use.
It sounds like a firewall issue on phone end - what router is it?
the link i sent you above was for more info by the way, i suggest you click it pls and fill it out.
Log in to the management console and from there press activity log > Capture
make a test call in and stop it.
Would be good to get one from the phone too, to see if the phone receives the SIP invite.
Check the 3CX Activity Log, to see if the set, has registered with a private IP, or the public IP of the router. If it has registered with it's private IP, then STUN has probably not been set up, on the phone, or has been set up incorrectly.
We had this today and on the router disabling SIP ALG corrected the problem.
Cannot receive incoming external calls.
...and what error, in the Activity Log, do you see, when this happens? Compare with an internal call..
Firefox Technologies
