- Joined
- Sep 24, 2015
- Messages
- 21
- Reaction score
- 5
For info: hosted at Azure, Version 18, 4 call Standard
SIP Trunk is connected, green tick on firewall, etc
Trunk works fine on another 3cx instance (at a different site with 3cx hosted on a windows box) so issue doesnt appear to be trunk provider.
Outgoing calls work perfectly.
Incoming calls dont register in the call or activity log - I can assign the incoming call to a handset, or divert to mobile, or voicemail all have the same result - about 20seconds of dead air before disconnection - my mobile simply says "calling" but nothing answers.
I have restarted all services, and even restarted the Azure VM. I would have thought it a provider issue but they assure me all is OK, and the fact it works when I set it up on another 3cx site suggests the SIP trunk is ok.
This happens for the main trunk number and any of the other associated DID.
I am at a loss. Its a fairly basic setup with just one phone and a couple of soft users until they move into a bigger office.
