No sources after upgrade to debian 10
infused
Hi Guys.
I only have the two sources in my sources.list on a number of 3cx instances. I am assuming this is incorrect and I should add the buster ones in?
deb http://deb.debian.org/debian/ buster main deb-src http://deb.debian.org/debian/ buster main deb http://deb.debian.org/debian/ buster-updates main deb-src http://deb.debian.org/debian/ buster-updates main deb http://security.debian.org/debian-security buster/updates main deb-src http://security.debian.org/debian-security buster/updates main
Hi @infused,
No this is correct. You don't need to change anything.
Something you may want to check is the discussion here: https://www.3cx.com/community/threa...push-for-the-web-client-pwa.88389/post-419547
"So basically at the moment, the primary intention of overwriting sources.list is to treat 3CX installation as an appliance as much as possible (regardless if it is installed from ISO, installed in a supported cloud provider or self-hosted)."
Reactions: infused
Hi infused,
I've found it's safe to modify these back to the correct Debian Buster repository, which is below. Just be aware that 3CX will overwrite this list again next update. It should be good enough to temporarily get you up and running however
Code:
I have not yet tested if putting these in, say, /etc/apt/sources.list.d/deb.list will persist. I can't say if this will collide with 3CX's repo.
gmacinit
