Not able to transfer
Rachid Ouasti
Good afternoon,
One of my client has 3cx with an office sync and is using Teams to make and receive calls.
When he receive a call and try to tranfer it to someone it works if :
- I put an external phone number
- or if I put the internal extension of the personne example 8292
But it 's not working if I start to write the name of an internal colleague and select him, I get the message Sorry we couldn't transfer the call.
Can you please help, I tried with different personn in the company and I'll get the same issue
We are experiencing the exact same issue as you with our 3CX V20 Teams integration. Have you resolved it? If so, could you share the solution with us?
We have contacted 3CX support, and they informed us that it is a limitation of the dialing script. Therefore, we must dial the extension number when transferring a call.
This was an issue that has been fixed in Update2
Have you updated to the latest version and check?
We plan to update the system this weekend. We will keep you informed.
Let us know the outcome
No i didn't find any solution, I don't know for the upadte 2 I'll have to ask colleague he is the phone expert, but he doesn't speak English.
I'll let you know
I will be waiting for your feedback.
Stephan Eusebe
