Not allowed
navin
Hello guys, Idk why all of a sudden all calls in outbound and inbound is not allowed but when i reboot the server it goes back to normal,
this happens every once in a week.
Dialed: Sir $$$ (+###########) → Via rule: docdx (+###########) → Via trunk: Elevate Calls Employee (+###########) → Not allowed
This is an config of the outbound rules from the old IT I didn't change it yet.
Rule NamePrefixOutbound Call from Ext.LengthDepartmentRoute 1Route 2Route 3Route 4Route 5
docdxAny12Elevate Calls, Jivana CareElevate Calls EmployeeBlockedBlockedBlockedBlocked
Go ---- -ecurityAny12Go Safer SecurityGo Safer SecurityBlockedBlockedBlockedBlocked
Leo ------Only0All11Elevate Calls EmployeeBlockedBlockedBlockedBlocked
12 Digit RuleAnyAll12Elevate Calls EmployeeBlockedBlockedBlockedBlocked
10 Digit RuleAnyAll10Elevate Calls EmployeeBlockedBlockedBlockedBlocked
11 Digit RuleAnyAll11Elevate Calls EmployeeBlockedBlockedBlockedBlocked
Outbound rule for XentigroupllcAnyAllAnyXentigroupllcBlockedBlockedBlockedBlocked
to onevoipAny202AnyElevate Callsone-voipBlockedBlockedBlockedBlocked
You would need to check event / activity logs for further clarification.
set your logging to verbose.
What OS is this on?
Reactions: Alejandro_3CX
The system is matching the outbound rule as you describe it is using the rule: docdx
Please check the user is included in one of these departments Elevate Calls, Jivana Care, I also suggest you to check the event log and see if there is any event regarding the voip provider.
Reactions: NikosT_3CX
Call or Registration to +########@(Ln.10000@Elevate Calls Employee) has failed. sip:192.76.120.1#:5060;lr replied: Forbidden (403)
You will need to check this with your voip provider since they are the one rejecting the call with the 403 forbidden.
Is this trunk IP based or uses registration? are you allow to dial the number, for example they may block specific calls...
this is user registration
have you checked the state of your SIP registration at the time of issues?
Try "refresh registration" instead of a restart the next time.
is your WAN IP dynamic?
Is this a supported sip trunk?
I tried refresh and reregister still wont work
So its currently down right now?
everything is green I green and connected. already send a logs in telnyx and waiting for their response.
That doesnt answer my question, and you havent answered any of my others.
it's home time for me today, but good luck.
Sorry I was responding to someone.
have you checked the state of your SIP registration at the time of issues? yes its registered
Try "refresh registration" instead of a restart the next time. also done
is your WAN IP dynamic? it was static now im suing dynamic
Is this a supported sip trunk? im using telnyx
My first thought was that your trunk registration had timed out. But if you say it successfully refreshes, and in my experience Telnyx is a reliable provider, then something else obviously is going on.
I would contact Telnyx support and let them know of your issue (in advance of the issue happening again). Let them know that you will be contacting them again when it happens so they are ready to test as soon as you call.
I would be curious to know is whether Telnyx is receiving your request at all. Also, whether they are logging any issues with registration. It may show green in 3CX, but that does not necessarily mean Telnyx is not having issues on their end.
/dev/simon
