Solved Not receiving any invitation email related to webmeeting
beonlinesoluciones
Trainee Partner
Hello
When I create an Videoconference, system report me this error:
Exception of type System.ArgumentOutOfRangeException occured in 'DoProcessWebMeetingStateCallback' line 699. Message: Count cannot be less than zero. (Parameter 'count')
ANd invitation email doesn´t arrive to external participants only internal
Email for audio only and the rest of email works perfectly.
Any idea?? Is V18
Hi @beonlinesoluciones,
Can you walk me through the steps you're following to create a video conference? What options are you selecting when creating the meeting?
I have version 18 of 3cx and what I do is click on the plus symbol that appears at the top left and then, whether I configure the videoconference for that moment or for later, it gives an error. It does not matter if I add the participants with legacy email or with google or outlook ... when I click on creating the video conference, I always get that error and only with the video conference.
Do you by chance use a custom template for the Webmeeting email? Also can you see the "MAILTEMPLATE_WEBMEETING_CUSTOM" parameter in Settings >> Parameters? If yes, copy the contents to a document on your desktop, then delete the parameter altogether.
Once done, try again, does it resolve the issue?
Reactions: Dunblue
Now it work correctly but email is in english and not customized. How can I customiize it again??
Thank you very much
Solved
SOLVED THANK YOU
No problem @beonlinesoluciones! Feel free to open a new thread if you require any further assistance or information!
Graham Robertson
