not recording calls when outbound has Password (SOLVED)
killmasta93
I was wondering if someone else has had the same issue, Recently i just realized that the outbound routes that have password do not record, I tested it by taking the password out and immediately it records. Any ideas?
Thank you
What kind of recordings are you under, in the extension level, queue?
Regards,
Claudio
Thank you for the reply, not really sure on what you mean what kind of recordings, this is what i have on the screen shots
Thank you
In your case you are recording in two different places, the route (first image) and the extension (second image).
Indeed I don't recall problems with that, so it's not technically a bad setup, but here are some tests to do.
  • Are you sure there aren't any recordings?, check if the actual recordings are in the recordings folder
  • Test your case without the recordings enable in the extension level (second image)
Regards,
Claudio
Reactions: killmasta93
Thank you for the reply, whats funny on the webgui does not shows but if i go to var/spool/asterisk/monitor i see the wav file which is labeled as out so funny
Thank you again
RRusev
