O365 integration stopped working 18.0.8. (939)
Romain974
Since the last upgrade i cant make O365 work again... The patchnote said :
Code:
Important: Reprovision your 365 app
If you already have 365 integration configured, then you’ll need to reprovision the app once you upgrade. For more details review the How to Integrate your PBX with Microsoft 365 Guide.
I try to reprovision the app
here the 3cx message :
and when i want to provision the apps here the error:
Azure app side logs :
must i delete de azure app before reprovision ?
Thanks for help
Regards,
Hi ,
I had to delete the previous app i made for sync , and use the new wizard.
And the sync is now ok.
Reactions: Charles_3CX
KylieWilderman
