Office 365 Integration
manfer
I have done every step on the documentation for Office 365 Integration and I get error:
Calendars.Read permission is missing. Please check if permission is assigned to the application and/or Sign In
I read other threads with same problem but the solution they suggest is not my case. I add the permissions to app and not to delegation and I still get the error.
I have created the app following every step on apps.dev.microsoft.com
Once you create the app there is a link to show the app in azure. I have even done that. I checked the permissions of the app in azure ui and the app permissions were not set. I added the permissions again there and the problem continues.
10646
rugga
