On-Premise v20 unable to download file
TBarker1989
SOHO User
I have an On-Premise installation running v20. I am trying to setup a Grandstream HT801 to my installation. I do the setup with the MAC address and everything. I get the prompt to download the cfg file but there is no file there. it is just the provisioning link. I am not quite sure what to do about that. I can access the server directly if I need to pull it direct off of the server.
Add your device MAC address with ".xml" at the end of the link and you can download the config file.
I see you are running the latest Alpha version, please note this is not recommended for production environments - this is meant only for testing.
Reactions: JohnS_3CX
@TBarker1989 That is the correct URL format
@JG55247 I should reiterate that Update 5 Alpha is only for testing, not production systems. When the next beta comes out soon you can upgrade out of alpha, and then later on to the final official release
LeeonLau
