Openvox B100P + Elastix 2.0.3
wlady
I've used asterisk many times with voip trunks and very good results. Now I'm trying to configure a PBX for the first time with a ISDN B100P card. The card is recognized under "hardware detector" of the gui, but I think there's some problem regarding the connection (maybe the cable or telco config??). Card is connected to NT1+ and configured in TE mode thru jumpers settings.
I post here some test made in asterisk CLI:
dahdi show channels
Chan Extension Context Language MOH Interpret Blocked State
pseudo default default In Service
1 from-isdn default In Service
2 from-isdn default In Service
pri show spans
PRI span 1/0: Provisioned, Up, Active
I'm worried especially for this last warning. Maybe I need a twisted cable? Can anyone suggest me what can I try ?
Thanks!
And what is the issue?
How should it work?
How should it work?
gone into /etc/asterisk/dahdi_channels.conf and deleted all 'group' and 'context' params and added:
group=0
context=from-pstn
regards!
I have the same problem with Openvox B200P and B400P and Dadhdi on Elastix 2.3.0-11. Everything is ok but PCI card is not communicating with ISDN. Like something is not ok in config file.
Can I post your config files fog B100P here so I can see what changes you made ?
Put the folowing conf files:
- /etc/asterisk/dahdi_channels.conf
- /etc/asterisk/chan_dadhi.conf
- /etc/dahdi/system.conf.
Thank you in advanced.
I did not make any moodify at conf files except than dahdi_cheannels.conf. See my last post for reference
regards
Wlady,
can you paste here your complete dahdi_channel.conf so I can see what have you done ?
I have similar problem as yours and for several days I am trying to solve it.
Thank you in advance.
Radoslav
CLTedu
