Operator cannot be deleted - Version 20.0 Update 3 (Build 659 Alpha)
ThePhone
Can't delete extension 100 that was initially created due to Operator cannot be deleted message.
System > Options doesn't offer the option to change the operator.
In V20 update 3, you can try to change the operator here:
You need to change the operator to something else and after that you can delete it.
ARKC
