Outbound call MS Teams doesn't work
Artem Khvostenko
New User
I have integration with MS Teams.
And I can't make call from Teams to external numbers, meanwhile I can from web https://softico.3cx.eu/webclient/
Also can call from web to MS Teams.
from MS Teams to web - can't.
Tested from 100 and 702
Dial plan was pushed to MS Teams
Hi!
Create a new Extension that is NOT synced with Teams and log into the WebClient for this extension.
Then call from Ext 100 from the Teams client to the new Extension.
Does this work?
I created 800 Ext (manual) and call from Teams(100) to 800(Android 3CX) - it doesn't work
Meanwhile if I call from 800(Android 3CX) to mobile number - works.
Also see in extended logs 3CX only call from 800 to mobile
Didn't see any other with 800 (I mean my attempt call from 100Teams to 800Android3CX)
Hi!
Does this work?
Hi, could I ask you is it right format number?
Yes, this looks like the right format although the number seems a bit short for a UK number.
