Solved Outbound calling not working after update to 16.0.676
Janwillem Ronken
Intermediate Cert.
Hello all
Since I updated yesterday our 3CX Professional to 16.0.676 I can't make any outbound calls over our SIPGATE trunk.
Inbound works fine, outbound gives this error:
Call or Registration to 0031xxxxxx@(Ln.10000@SipGate Team (Trunk)) has failed. 217.10.68.150 replied: 403 Username in From Field required; from IP:217.10.68.150:5060
Any idea why this suddenly happened, and how to solve this?
Many thanks
Janwillem
Hi Janwillem,
In your trunk settings, what's your Type of Authentication ?
Do you have a Authentication ID and password entered ?
Did you run the firewall test ?
Paul
From the error seems that sipgate requires the username in From field.
I suggest to activate Verbose mode in Activity Log and to check the INVITE the PBX is sending to sipgate.
Hi Paul
yes, all was set and working before.. in the outbound parameters however the
From: User Part was set to Leave default value, when I changed this to AuthID it started working.
I am not sure if this was set before and removed when I updated yesterday but until the update it all worked fine.
Problem solved for now.
Thanks for your reply!
Janwillem
Kayla Norris
