outbound calls from group to display group name
Chris Stuntz
Is it possible to have the outbound calls from specific groups configured in 3CX to display the group name rather than the # on the recipient's caller ID?
If you are talking about name display, to external callers, then that can be hit, or miss, at the best of times and depends on what your provider allows/accepts. Many do not accept name display, and the recievibg end will get a name that matches the number sent if a database lookup is done. As far as configuring a common name, for a group of callers....I have not seen a feature of the sort mentioned before
natedog
