Solved Outbound calls
netsystems
I have my 3cx installation in the cloud, with two lines working inbound and outbound adding new lines to my configuration now have issues with outbound calls 404 call not found when using gxp 2130 and call failed when using the softphone
Really confused now
The 404 is coming from ...your provider? If so, what does the 3CX Activity Log show for the number being sent...is it in the correct format? Might this be an incorrect caller ID issue. Some providers do not accept any caller ID being sent, other than what you have "registered" with them.
thank you @leejor it worked after setting the outbound call ID
Kayla Norris
