Solved Outgoing call doesn´t work
Vettel
if I call numbers with the format +491234567890 it doesn´t works.
I get there the error "Not Found" on the display.
When I call +490123456789 it works.
That´s the outgoing rule.
Has anyone an idea, how it will works?
Thanks!
Best Reagards
Thomas
Hi @Vettel
Do you have another outbound rule set up in your PBX? Also is E164 enabled under the settings menu? If so what settings do you have there?
the issue was in the E.164 settings.
Now it works.
Great. Thanks!
Reactions: YiannisH_3CX
Glad I could assist
Bluebox Global
