outgoing calls from 1 number
Zivx
Hi Team,
how i can config that all the call going out from specific number from the trunk?
ex:
trunk: 05511111-05511119
specific number to out going calls is: 05511115
Thank Team!
I'm not clear if you are talking about the caller ID that should be sent. If it is caller ID, that that can be set, as a fixed number , in each outbound rule, if desired.
If that isn't it, then you will have to provide a better explanation.
i mean caller ID, i will try to explain better:
i have sip trunk with 10 numbers in the range and i need split it into 2 PBX (2 different companies).
company X should use 05511111-05511115 for inbound&outbound
company Y should use 05511116-05511119 for inbound&outbound
company x need caller ID 05511115
company y need caller ID 05511119
I hope it's clearer now
add the number to outbound Id to each extension
or
Create outbound rules based on extension and add the required outbound caller I’d
on the extension, you can use 10-20 , or 10,11,12
Normally, if you set an outbound caller ID against an extension, (that extensions DID number), then that is what will be sent, as long as your provider allows this. If an extension calls using an outbound rule, with a caller ID set in that rule, then that caller ID will over-ride the one set in the extension settings.
There are some caller ID based options, in the outbound trunk settings, that, if changed can affect how this works as well.
SG_F7
