outgoing calls problem
atlantisegidek
Forum User
Hey everyone.
I have pro licence and version number is 16.0.612
My problem is that the outgoing calls look like this. The phone does not ring. The photo below.
edit: And this happens occasionally. It returns to normal after 3-5 minutes.
Incoming calls are also no problem.
What is the problem? Thank you :(
Hi, with so few information, it's impossible to give any assistance. Do you get the call on the 3CX server ? any logs ?
Reactions: atlantisegidek
Yes the call is coming.
I make internal calls. No problem.
So what does your 3CX server say ? outbound rule issue maybe ? is the same call working from a webclient ?
Look at the 3CX Activity Log, to see exactly what happened with the failed call. Post the log, if you are unsure as to what it is telling you. Be sure to X out any sensitive information.
SIP Server/Call Manager ID: 4101
Extension 1301 is unregistered, removed contact: sip:1301xxx.xxx.x.x:59101;rinstance=0-52844d27050749c4sf3e28ab4344e371;ob, received from: xxx.xxx.x.x
3K8iMGWviZ
